67 Deville water pump replacement problems
Started by jims427400, August 07, 2018, 09:08:36 AM
jims427400
Hi all,
My first of many posts I'm sure..
My wife has a 67 DeVille, 30K original miles that the water pump began to squeal. I'm also a vette guy so I've done a lot of work on 60s big block cars. I started to remove water pump bolts and 2 short bolts that thread into the timing cover sheared off and 1 long bolt that goes through the timing cover then into the block won't turn at all and I'm worried it's going to break as well. Has anyone dealt with broken bolts in this area and is it difficult to get the timing cover off to get these studs out?
The car is a 429 w/AC and has never been rebuilt.
Thanks all,
Jim
cadillactim
The short bolts that shear off is common. If there is enough of the bolt sticking up I take a torch and heat the aluminum cover a little around the bolt, attach vise grips to the bolt and it unscrews right out. If they break off flush, then you have to drill them out.
The long bolt may be a bigger problem. What likely has happened is the steel bolt is corroded in the aluminum cover. Not only may the bolt break off, you will like damage the cover trying to pry it off. You can try heating the cover and the block where the bolt goes in and then see if the bolt wants to turn.
You are at the "committed" point now, and worst case scenario us having the break the front cover around the seized bolt. Just be careful with that bolt, as you don't want it breaking off flush with the block.
Be prepared to get a new cover, and then be sure to put anti-seize on the bolts.
Tim Groves
Try watching some of these videos about removing rusted nuts and bolts with a MAPP torch and candle wax.  Pretty amazing, be careful with that aluminum.
https://www.youtube.com/results?search_query=loosening+bolts+with+candle+wax
@Tim Groves --- thank you very much again for your assistance over the phone yesterday concerning my NSS.
Geoff N.
jims427400
Thank you Tim and Geoff.. I guess I'll through a little heat on it and cross my fingers. Having to drill out the aluminum cover, I'm not sure I have enough room between the cover and radiator. I really don't want to think about having to pull the engine out to get access to remove the aluminum cover and drill out the studs.
Thoughts?
Jim
Mike Josephic CLC #3877
If worse comes to worse, pull the radiator out.  That's
much easier than pulling the engine and will give you
sufficient room to work.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Agreed.  That's what I did on the '66 I used to own when I replaced the water pump and timing chain about 20 years ago.
jims427400
Great idea Mike, does anyone recommend changing the timing chain while I'm there? Car only has 30,000 miles.
Jim,
This is what it will look like under the cover.  Pull the radiator, pull the front damper and crankshaft hub pull the distributor and fuel pump and then unbolt the timing cover,  With the cover off you can survey the "damage" and while you have got the cover off a new timing chain is easy.
jims427400
Well Greg you make it look easy.. Can I ask you how hard it was to remove the radiators?
Jim
Jim
The radiator just needs the hoses disconnected the shroud top piece removed and when you disconnect the trans cooler and unbolt the upper radiator support brackets it should slide right out. This will give you the clearance you need to work easily.
jims427400
I do have the shop manual. It has come in handy in the past.
Good deal.  You will find that Fisher Body Manual very useful from time to time also.
jims427400
Update..
With a little heat from the torch I was able to remove the last bolt from the WP. And the 2 broken studs came out easily with the candle wax trick suggested to me earlier.
Pictured is the old water pump and can someone tell me if it looks like the original WP? It looks like it has some original looking GM markings. I have purchased a generic pump from cadillac parts store.
Thanks for all the help,
Jim
Chuck Swanson
#14
Yes, looks original.  Save it as it does not have the extra outlet like the repros.  You may even want to just get yours rebuilt, but don't throw it out :).  Hard to find so don't return as core either .  Also, a guy on ebay sells replacement bolts.   Use two o-rings on the top of pump for the crossover.  Chuck
CLC Lifetime
AACA Lifetime
66 Sedan DeVille hdtp
66 Calais pillar sedan
66 Series 75 9-pass limo
65 Fleetwood
07 DTS w/ Performance pkg.
69 Dodge Coronet R/T
jims427400
Chuck,
I believe my WP kit only has 1 O ring but I'll check. As far as the original WP I've seen rebuild kits for mine. Is that hard to do or I should find someone to send it to?
This is a pic of my new WP..
Jim
"I believe my WP kit only has 1 O ring but I'll check"
Save the old "O" ring and reuse it along with the new one, been there done that with 429 pumps.
jims427400
