Removing the horn button on a 1968 DeVille
Started by wingercasey, August 13, 2018, 10:50:01 PM
wingercasey
I want to install a signal light switch in my 1968 DeVille convertible. The problem is that I can not remove the horn button, which is the first step. The steering wheel has three spokes, each of which has a hole which, I would think, is where I should put my Phillips screwdriver in to extract three screws and then remove the horn button. I have been unable to remove the screws. What am I doing wrong? What is the trick? Thank you.
Highwayman68
First: Go on eBay and purchase a Shop Manual on CD!
Here are the instructions from the shop manual.
Julien Abrahams
If the '68 , steeerung wheel resembkes a '67 steering wheel, the at the bach of the wheel you will find three holes. Remove th screws inside with a Phillips screwdriver. The horn pad will come off. Be carefuk ypyou don't bendor loosen the springs.
1951 Buick Eight special
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
wingercasey
Thanks, Mark. I appreciate the help. I ordered what I thought was the shop manual, but I received the 1968 Body By Fisher manual instead. I will do as you suggest and order the CD.
wingercasey
Thanks, Julien,
When I got my eyeballs lined up through my multifocal lenses and the light just right to look in the three holes, I found that the screws are slot head screws. I expected Phillips. I got the screws out and back in. When I got it apart, I had the wrong repair kit. Maybe they gave me one for a car without the tilt/telescopic feature. I couldn't see any way to get the plastic switch part out - it seems bigger than the opening at the top of the steering column. I decided to live with it, so I put it back together. The signal lights work, but I have to hold the lever up to signal a right turn.
Highwayman68
The tilt/Telescopic column is not the same as the standard straight colmn. The part you are looking for is very hard to find and is usually very expensive.
