49 convertible need LH frt vent window regulator.
Started by rodsragsnrides, August 24, 2018, 10:39:35 PM
rodsragsnrides
Looking to buy or trade for a 49 LH Frt vent window regulator.
I have one I can rebuild but my shaft tip  is so worn, the window handle will not properly stay on.
I have a rh hand extra that is very good shape & If I cannot find one I will have to destroy the rh extra to make one out of the 2...
Any chance some has a extra lh & needs a rh?? or just a bad left hand or rh I can cut the end off to weld onto mine... To be clear I need the piece with the drive gear that actually holds the handle on.  Have a few other parts to trade as well or will pay cash, thx Curtis Scarrow Saskatoon, Sk
Curtis Scarrow Saskatoon,Sk
Barry M Wheeler #2189
Try Bob's Buicks as a 1949 Buick Super/Roadmaster will interchange.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Brad Ipsen CLC #737
I always take these apart and put new grease and mix and match parts to get good ones but is the shaft and gear different left and right.  They may not be.  The convertibles generally have a longer shaft on them so you can't interchange with a sedan but if you are willing to weld the shaft on, which I have done also you can use just about any shaft 39 and up.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
rodsragsnrides
Thanks brad,  I will rebuild this conv one and find a 39 up shaft to weld on, probably better to find a door handle one as well....
I'm not one to ruin a perfectly good part even though it's for a modern custom....
Jeff Maltby 4194
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
