CRANKSHAFT PULLEY
Started by BOBBY G, December 03, 2018, 05:20:41 PM
BOBBY G
 I FOUND A CRANKSHAFT PULLY 2 GROOVE FOR MY 39 LASALLE BUT IS STATES FOR A 346 ENG   WILL THAT FIT MY 39 LASALLE 322 CU IN ENG
IT APPEARS MINE  IS DBLE GROOVE
APPRECIATE ANY HELP THX BOBBYG
Fred Pennington 25635
Should work as long as the pulleys line up. Some 346s had a harmonic balancer the 322 did not. They don't work like modern balancers. They use weights and springs and can be problematic to rebuild.
Fred Pennington, CLC 25635
1940, LaSalle 5019
1940 LaSalle 5019 parts car
1968 Ford Bronco
1973 Mustang Convertible
2012 Shelby GT500
BOBBY G
Bob Hoffmann CLC#96
Putting a balancer on a 322 may make for a balance problem. What is wrong with your old pulleys? What is your budget for the correct pulleys? Please advise.
Thanks, Bob
BOBBY G
bob . i found one on ebay for a 346 but mine is a 322cu in .  its a 2 groove on ebay
for 75 i an try it becuz mine is bent so car vibrates when u rev up the eng
its not a harmonic balancer
any info appreciated i only know enough to be dangerous!!!!!!!!!
SELLER THINKS IT MAY FIT
Bob Hoffmann CLC#96
Hi Bob, It will probably fit but it MAY cause another balancing problem. I'll look tomorrow to see if I have the correct one for you.
Bob
C Gorgas
Also pay attention to the timing marks. I received one and the timing marks on the one I received were about 30 degrees out; I was fortunate to look before I installed saving a lot of headache. It probably had been reworked.
