1957 eldorado brougham
Started by denis3626, July 27, 2015, 09:50:44 PM
denis3626
Hi, I am in final negociation to buy a 1957 eldo Brougham (#144). I'm looking for the number on the engine and on the frame. Does somebody have pictures identify exactly the place where it suppose to be.  Thank you in advance.  Sorry about my english :) I'm better in french.
D Lacroix
Denis Lacroix  (clc member 15021)
Laval, Québec Canada
1940 Series 6267
The VIN is stamped on a flat machined surface from the block, just in front of the passenger cylinder head, as well as on the frame, also on the passenger side, right behind the front engine support. You have to clean both places because the stamping is not very deep.
The shop manual has pictures from both locations. If you need it, I have an original 1957 Brougham shop manual supplement, in decent shape, but you will also need the regular 1957 Cadillac shop manual.
Are you located in France?
chrisntam
How do you know he's in Canada?
Sure would be nice to have people's (general) location noted to know (about) where they are located......
1970 Deville Convertible
Dallas, Texas
His email address, which the Administrators can see.
Plus the ISP Host Name.
chrisntam
Dallas, Texas
David King (kz78hy)
Good luck on the purchase.  You should check out and join the Eldorado Brougham Chapter as it is the place for these cars.
Regards
David King
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
denis3626
yes canada  laval,province of Québec
I added the location.
Thanks Mr Zimmermann for the info.  the seller has these manuals.
1940 Series 6267
GKC
As described in an earlier post,... I found the number on the top of the frame just behind the upper contol arm on the pass side. This one was proceeded and followed by a star stamp. I used a yellowish piece of chalk to highlight it better.
It was tougher to find the engine number but I easialy located it and documented it ( again with chalk) when I had the ac pump off and the water pump, ( for replacement) My photos are not on this device but on my phone, I will try and post those later.  GKC
When did they switch to putting the numbers on the driver’s side or left side?
In 59 and 60 and other newer years the numbers are down on the frame on the drivers side behind the radiator support on the flat part of the frame. Engine numbers are also on the left side on the casting of the block above the oil pan.
Dan LeBlanc
Wow, this topic was 3 years old in July.
Dan LeBlanc
chrisntam
Quote from: Dan LeBlanc on December 07, 2018, 07:11:50 AM
We've run out of stuff to talk about?
Dallas, Texas
