1955 Body Codes
Started by Bill Young, March 14, 2019, 08:13:04 PM
Bill Young
Does anyone know the Body letter codes for the ( Style ) for 1955 Cadillac's ? I have seduced that M is the Fleetwood Sixty Special.
Bobby B
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Bill Young
Thank You Bobby , except that data does not state what letters are accorded with each body style.
Bobby B
Quote from: Bill Young on March 14, 2019, 10:42:16 PM
Bill,
Shouldn't that be incorporated into the 60XX, 62XX, or 75XX, 4 digit plate code?
                                                      Bobby
1971 Datsun 240Z
1979 H-D FLH
Mike Josephic CLC #3877
Hi Bill:
I must admit when I first saw your question I was a
bit puzzled myself.  The "letters" are used together with
the numbers to denote body "style" as follows for 1955:
6237 -- series 62 base coupe, no letter
6237D -- series 62 Coupe Deville
6219 -- series 62 base sedan, no letter
6239D -- series 62 Sedan Deville
6237S -- Eldorado (S = Special Convertible)
7523 -- 60 Series Fleetwood Special Sedan, no letter
7533 -- 75 Series Imperial Sedan (limo), no letter
Please note that after the number / letter in the style
coding that an "X" was added if the car was delivered
with power windows.  For example, a Sedan Deville with
power windows would be:  6237DX
I'm unable to find in my info any code "M" that you
mention.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Bill Young
Thank You Gentlemen , on the record of cars built from the factory the nineth column " Style" it shows these codes Z,K,M,J G, F, M I have figured out that M is the 60 Special my car but no info on the others. If anyone with a 1955 has sent for their Factory sheet what is the style letter accorded with your car please ?
J. Gomez
William,
Are you referring to these "body styles" codes???
These and other data can be found on the '55 Data Book that you can download from the GM heritage site.
HTH
J. Gomez
CLC #23082
Bill Young
Bingo , Mr. Gomez. Thank You very much.
Bill Young
Does anybody know what CWC means on the 1955 Factory sheets. It is located 4th. column in from the right side where the Key Codes were?
Hello Bill:
Now that you mentioned you were looking for the
"Style Codes" from the build sheet, I understand what
you were talking about.
Mine shows "E" for Eldorado.
2004 Escalade
