1960 Can anyone tell me how this plug
Started by 60eldo, August 10, 2020, 01:41:23 PM
60eldo
1960 Power window motor, how does this plug come off Im pulling and nothing
Jon. Kluczynski
Cadman-iac
On the side you don't show there, it should have a small locking tab that you press before you pull out on the connector. It might be broken off, so it's not visible, but it could just be rusted in place too. Not all of those style connectors have a locking tab.
Rick
PS: here's a picture of what it looks like. I was thinking it has just one tab on the bottom,  but it actually has two,  one on either side. If those are broken off, you may need to pry it out if no other way works.
CLC# 32373
60eldo
Jon. Kluczynski
60eldo
Jon. Kluczynski
Cadman-iac
Quote from: 60eldo on August 10, 2020, 02:04:28 PM
   Got it out thanks
Good,  glad it worked out for you. They put those tabs on so that the connector doesn't work itself out from all the vibrating the door gets.
CLC# 32373
