PLANNED SITE MAINTENANCE (RESCHEDULED) Please note that the forums will be unavailable on March 5th, starting at 09:00 EST This down time is expected to last between four and eight hours, but could be longer if any issues arise. The purpose of this maintenance is to install a user selectable Dark Mode theme. To keep the current Light Mode theme, no action is necessary.
Carter versus Rochester
Started by Davidcamper, October 09, 2022, 08:31:56 PM
Davidcamper
Hello,
I just bought a 1951 series 2. It has a Rochester BB carb and was wondering if it's worth putting a Carter WCD on instead.
Thank you,
David
Unless there's something wrong with it, I don't see you making much improvement with these early carburetors.  I rebuilt the WCD on the '49 P and it worked just fine.  Very simple carbs.  Not much can go wrong, either way.
Davidcamper
Thank you, I have a WCD in a box in the garage and heard those were easier to rebuild with a kit than the Rochester that's on it. Most of the 1951 Caddy's I look at have the WCD so I was wondering if maybe they were better as far as engineering. I'm not really concerned about economy.
Thanks again,
David
