1962 390 No-start Update
Started by midwestisbest, July 22, 2023, 08:46:57 PM
midwestisbest
UPDATE
Rookie mistake: When using a remote start, you MUST have the key in the ON position if you expect the engine to run and continue to run.
After putting the key in the ON position, here's the result:
Yes, its a lot of blow by. Maybe the rings will loosen up more.
For now, I need to get it to idle.
