UPDATE: Found! need right (passenger) side upper control arm for my 68 CdV
Started by Steve W, May 13, 2024, 06:57:17 PM
Steve W
Found! Thank you Jeff Burland/Willington Cadillac!
I need the right side (passenger side) upper control arm for my 68 Coupe deVille.
We were replacing the bearings when it was discovered that the arm itself is shot!
I'm told 65-68 are the same?
I saw one off of a 66 on ebay, but the guy sent me the pic and it looked like rust was eating away at the lower portion.
I don't mind grease and grime and maybe somne surface rust, I can clean it up and paint it myself, but these are HEAVY cars, and my main concern is structural integrity. And that the hole that the bearing goes through isn't worn out (that's the issue with mine).
Thanks.
Steve Waddington
1968 Coupe deVille
North Hollywood, CA
CLC Member # 32866
Jeffrey Burland
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
