Any tips for cleaning seat belt fabric?
Started by chrisbutnut, November 02, 2024, 04:59:51 PM
chrisbutnut
I pulled my rear seats out of my 68 Coupe DeVille so I could remove the rear quarter panels (I'm having them redone, along with the door panels).  Any tips for safely cleaning the fabric on the seat belts?  I don't expect them to be perfect, but am pretty sure I could make them look a lot better if I can figure out the best way to do it.
Mike Josephic CLC #3877
There is a product called "Tuff Stuff" that is a fabric cleaner that works on all types of cloth and rugs.  I've used it and recommended it to others as well.  It comes in a spray can and is easy and safe to use.  It cleans without fading the colors.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
chrisbutnut
Quote from: Mike Josephic CLC #3877 on November 02, 2024, 05:32:11 PMThere is a product called "Tuff Stuff" that is a fabric cleaner that works on all types of cloth and rugs.  I've used it and recommended it to others as well.  It comer is a spray can and is easy and safe to use.  It cleans without fading the colors.
Thanks!  I'll try it.
Highwayman68
I put mine in the dishwasher and what a difference they were afterwards. So soft too.
Would like to have The Chattanooga Choo Choo
chrisbutnut
Quote from: Highwayman68 on November 02, 2024, 09:37:25 PMI put mine in the dishwasher and what a difference they were afterwards. So soft too.
The dishwasher didn't fray the fabric?  Did you put the buckles in the dishwasher too, and did you use the heated drying or no?  Great suggestion!
billyoung
I just cleaned mine using dishwater detergent using a sponge and then rinsed with clean water and it worked great. Chris lets talk.
Age 70, Living in Gods waiting room ( Florida ) Owned over 40 Old Cadillac's from 1955's to 1990 Brougham's. Currently own a 1968 Cadillac DeVille Convertible and a 1992 Cadillac 5.7 Brougham.
Highwayman68
Quote from: chrisbutnut on November 02, 2024, 10:03:35 PMThe dishwasher didn't fray the fabric?  Did you put the buckles in the dishwasher too, and did you use the heated drying or no?  Great suggestion!
No fraying. I did put it on Sterilize heating to ensure the moisture was removed immediately to eliminate rusting. That was 3 years ago and they still look great.
