1948 Cadillac Engine Information
Started by Gary Roggenkamp, May 05, 2005, 06:23:44 PM
Gary Roggenkamp
I have a 1948 Cadillac engine that I am trying to fire up.  Can someone provide me with the following information?
Firing Order
Points Setting
Spark Plug Gap setting
Type of Automatic Transmission fluid
Timing Setting BTC
Appreciate your help.
Gary
H Desser clc #19416
Quote from: Gary RoggenkampI have a 1948 Cadillac engine that I am trying to fire up.  Can someone provide me with the following information?
Firing Order
Points Setting
Timing Setting BTC
Gary
In reply to your questions about 48 engine
Firing order 1-8-7-3-6-5-4-2  (#1 is left front)
Points set at .0125-.0175 or cam angle of 31 degrees
Timing is 5 degrees BTDC, indicated by IGA mark on crankshaft
Spark plug gap is .028 - .033  AC 104 plugs  10mm
Any of the newer fluids work but dont mix if you already have some in and the trans is old.  Take down pan and drain and clean screen then takle new fluid, but make sure you also drain torus at flywheel.
Herman
Jeff Malby 4194
Herman. How is the 48 convertible restoration going ?
Jeff 49 coupe
Herman CLC #19416
Jeff
A slow process now as trying to make a decision on who, and how much to spend on the job.  Estimates from $14,000 to $20,000 and climbing.  Mostly done otherwise just need to finish up instrument horseshoe and make a few connections and install windshield and s/s trim
Herman
