WANT TO BUY A/C Heat Control Dial for '70 Cadillac Convertible
Started by FRANK STAGNITTO, June 20, 2008, 01:51:26 AM
FRANK STAGNITTO
I AM LOOKING FOR A COMPLET & WORKING A/C--HEAT CONTROL DIAL LOCATED IN THE LOWER INST.PANEL. ON THE LEFT SIDE OF THE STEERING WHEEL  PLEASE ADVISE IF YOU CAN HELP.
THANX,
FRANK STAGNITTO CLC# 13539.
G'day Frank,
I took the liberty of changing the heading to reflect that you are wanting to buy a part, and not a complete car.
Frank,
At the risk of seeming simple (or special as they say in Texas), is your Contoller bad and how do you know?
If the first question is a moot point, I would recommend Old Aire in Dallas, Texas.  I have faith in their quality of workmanship.
If that doesn't pan out and if calls to all the regular Cadillac "recyclers" comes up blank, perhaps we can diagnose and repair your controller.
Greg
Ted in Olympia WA
Anybody know what year is the same as the 70?  I might have a 1971.
TED
Selling used Eldorado Parts from 1971-1978.  Member Number 25659.
FRANK STAGNITTO
THANX TED, I CAN USE ALL THE HELP I CAN GET.  HOPE SOME ONE OUT THERE CAN ANSWER THE QUESTION.  I WOULD THANK THE PART WAS USED IN '71 OR EVEN AS EARLY AS 66.67.& 69.
I'LL STAY TUNED.
FRANK
According to my ’74 parts book the CONTROL, INSTST. PANEL, HEATER AND AIR CONDITIONER for the ’70 Cadillacs (except 75 series) is the same as the ’69 Cadillacs.  But the ’71 carries a different part number.
Frank,
Glen's parts book is correct.  The 69 and 70's were the same.  Anything earlier or later is a different physical shape and the actual controls are not the same in operation.  I go back to an earlier question of the control head having been correctly tested and what part has proven defective.
For this era if the used part cannot be found, and there is no one offering a guaranteed replacement, a component by component test can usually result in the replacement or repair of that component.  Believe it or not it is not "rocket science"
Greg
FRANK STAGNITTO
THANX GREG.  I AM HEADED TO HOME, PALM SPRINGS TOMORROW AND I WILL CHECK THINGS AT MY SHOP.  GOOD TO HEAR FROM GLEN, & YOUR AGREEMENT, THAT ONLY THE '69 & '70 ARE THE SAME.
STAY TUNED.
FRANK
