can anyone identify this external vacuum pump application?
Started by tonyp, March 07, 2009, 07:44:55 PM
tonyp
this pump came in the pile of parts with my dissassembled 32 town sedan.i have just purchased a complete 1932 353 engine and will be selling all but the  crankcase/cylinders/heads and manifolds from the original engine.any serious help appreciated.the bolt holes are in line with the shaft where they are offset on the motor i just bought so it must be a different application.
tony patterson
Peter Nieuwlandt
It could be a vacuum pump to help the fuel flow from the fuel tank to the vacuum fuel tank wich sits on the firewall.
Sorry I'm not familiar enough with 32 to be sure.
peter
Peter Nieuwlandt
CLC 17863
Don Rundgren
32 was the first year for a mechanical fuel pump, they eliminated the vacuum tanks on the firewall. They did still use a vacuum pump mounted at the back of the motor for the windshield wipers and the vacuum brake assist on the V-12s. You need to ID that part number for application.
Don
McKinney, Texas
