Repost: Slow windows
Started by robailey, March 17, 2009, 07:53:02 AM
robailey
Not sure what happen to my first post, but here goes.  The windows on my "87" sixty special are all really slow going up.  The car did sit for five years.  Should I try to fix the problem or is it time to replace the motors?  I am finding that parts are getting harder to find.
Rob
Rob Ailey
Seymour, TN
1975 Coupe Deville
1987 Fleetwood Sixty Special
2014 XTS
Otto Skorzeny
The first thing I would do is spray silicone lubricant into the window channels on window edges. Sometimes they just get tight. That might help a little or it might be all that's needed.
If that doesn't work and you take the door panels off, lubricating the mechanisms might work. Sometimes the grease hardens up or gets full of crap. Clean out all the gunk and put new grease on the mechanism.
fward
HUGE VENDOR LIST CLICK HERE
Roger H
low voltage could be a factor,  is the charging system at 14v running?
Roger Hundtoft
1936 Fleetwood 8509
Lynnwood Wa
