Oil pan removal on a 57 Seville
Started by Dave Shepherd, May 02, 2009, 10:08:11 AM
Quick question here, can the pan come down without lifting the engine, just dropping the steering linkage and starter?  Thanks for any help.  Shep
J Kjerrulf
Short: Yes.
A bit tricky to get the gasket right on reassembly but you'll figure it out.
/J Kjerrulf
Eldorado Seville 1957
Thanks for th info, I use fine black thread though the bolt holes to tie the gasket onto the pan to hold it it in place.
