12 cylinder distributor caps
Started by M. Patla 13876, August 24, 2009, 01:47:26 PM
M. Patla 13876
Hi   i recently bought a 12cyl. distributor cap that was marked 1931 cadillac v12. of course when i got home it was too small in diameter. it measures 4and nine sixteenths in diameter. i now know the correct diameter is 5.150 for my car.it is made by delco remy how can i identify it ? i do understand that a twin ignition is also a possibility such as nash could it be 1934 35 36 37 cadillac v12 thank you matt
Bob Hoffmann CLC#96
#1
V-12 caps were the large diameter from 31 to 33. 34 to 37 were a smaller diameter. You need someone to measure their 34 to 37 cap I'll try to get hold of him, but someone may get you a faster answer.  I have a friend who needs a 37 cap if that's whast it turns out to be. HTH, Bob
Stinson
Quote from: M. Patla 13876 on August 24, 2009, 01:47:26 PM
Hello, I would be interested in purchasing the '37 distributor cap if Bob's friend does not.
Many thanks, Ty Stinson
CLC22330
Ty Stinson
CLC22330
Bob Hoffmann CLC#96
Ty, thank you for your consideration! Are you in a position to measure your cap tonite? My friend can't get to his until later tomorrow. Let's find out if it is a V-12 cap. Bob
Stinson
Quote from: Bob Hoffmann CLC#96 on August 24, 2009, 10:00:31 PM
Hello Bob,
Yes, I will measure mine and post the size for you.
Many thanks,
Ty
Ty Stinson
CLC22330
Stinson
Hello Bob,
Sorry for the delay, I just got home.
The outside lip of my '37 V12 cap is 4 and 11/16. The inside lip is 4 and 6/16. Hope this helps.
Ty Stinson
Ty Stinson
CLC22330
Bob Hoffmann CLC#96
Hi Ty,
thanks for checking. It looks like what Matt has is not Cadillac. However, now that he has your information, he should be able to determine it for sure. Lets see what he says.
Regards, Bob
Otto Skorzeny
#7
Post some photos of these things and it might be readily obvious to someone exactly what cars they fit.
fward
HUGE VENDOR LIST CLICK HERE
Stinson
Quote from: Bob Hoffmann CLC#96 on August 25, 2009, 06:53:15 PM
Hi Ty,
Regards, Bob
Hello Bob and Patla:
I have checked my Cadillac/LaSalle shop manual for 1937 and find that the distributor cap part is listed as Delco-Remy type number 667-C for the '37-85 V12. I don't know if this number is on the distributor. According to the Authenticity Manual for Class 7 and 9 -Fall 2006 page 55 the 667-C fits the 370D, '36-80, and the 85. This manual also states (on page 9) that the 667-C also fits the 1934 and the 1935 370D-40.
So, it looks like we need John Tozer and Gene Mene to advise us of their findings. Many thanks, Ty CLC22330
Ty Stinson
CLC22330
Don Rundgren
Matt,
I assume you are looking for a 1931 cap. I have a list showing a number 1850895 for the 31 to 33 cap, not sure if this is a GM or Delco number and not even sure the number is correct. I have been told that both the cap and the rotor for the early V-12s are basically unavailable as NOS items and are extremely hard to find used. Question for the experts: have these items ever been reproduced? If someone had the ability to produce a superior copy of the originals I know I would be interested for my 32.
Don
McKinney, Texas
M. Patla 13876
                           THANKS FOR THE RESPONSE TO MY QUESTION. THIS CAP MEASURES 4AND NINE SIXTEENTHS INCHES OUTSIDE DIAMETER . IT MUST BE FROM ANOTHER CAR THAT USED DELCO REMY IGNITION SYSTEM. MAYBE EVEN AN OLD FIRE TRUCK OR INDUSTRIAL APPLICATION. ANY MILITARY USE?  I DID SPEAK TO SOMEONE YEARS AGO WHO SAID THERE WERE REPRODUCTIONS. I HAVE NEVER SEEN ONE.  THE ONE ON MY 31 IS WAY OUT OF ROUND BY 5 SIXTEENTHS OF AN INCH. I THOUGHT OF TRYING TO REPAIR IT. BUT HOW??  POSSIBLY HEAT IT IN THE OVEN AND QUICKLY CLAMP IT TO THE DISTRIBUTOR I WOULD LIKELY BLOW UP THE STOVE.   IF THEY CAN MAKE OLD FORD CHEVY CAPS WHY NOT V12 V16 ?  LOW DEMAND ?
Otto Skorzeny
#11
This guy has lots of NOS ignition parts. Caps rotors, etc. among other things. Maybe you'll get lucky.
Marx Parts  Bob Marx    715-652-2405  Arpin, WI      www.marxparts.com   all NOS and NORS
Call them. The website doesn't list everything they have.
fward
Stinson
Hello Matt:
I will measure mine again this evening. Perhaps mine is also out of round, but the car runs well. It measured 4 11/16 outside rim and 4 3/8 inside rim. However, it could be out of round compared to your 4 9/16 measurement.
Ty Stinson
CLC22330
Ty Stinson
CLC22330
Didn't the V16s use 2 distributors, each 8 cylinders?  Any chance of doing this on the 12, of course I would use HEI 6s.? Bruce Roe  CLC # 14630
Stinson
Great idea!
Apparently this was done for the V12 years ago and all sold out quickly. Seems by now there would be a need for both the V12's (large and small caps) and for the V16's.
Not a bad idea to have one extra cap and perhaps even the dual rotors being made at the same time(?).
Ty Stinson
CLC22330
Ty Stinson
CLC22330
This is just a wild shot, but there is a company making and of course selling distributor caps for the Liberty Aircraft engines.  Liberty's used Delco Distributors and they were of course 12 cylinders.  If someone needs a Cadillac cap you might google liberty aircraft engine parts and see where that leads.
I was on the Antique Aircraft Engine Societies website when this turned up.
Good luck and good hunting.
Greg
Otto Skorzeny
That's a great suggestion, Greg. You beat me to it. There are many many parts for lots of old cars that are still made for non automotive uses that we just aren't aware of.
Some Packard straight eights are still used in the marine industry.
The suggestion to have the club make parts is outstanding. I think this should be an ongoing and regular job of the club. Perhaps a wish list from members could be developed and new parts could be made by the club for those parts most sought after.
Advance orders could be taken prior to manufacture to help safeguard the club's investment.
Just like the CCCA or whoever makes the special 15w-40 motor oil, the CLC could generate a revenue stream that might, in part, make up for the loss if and when Cadillac and GM pull the plug on financial support.
Between the internet, Self Starter and Hemmings, it's much easier to get the word out to potential customers than it was in the past.
Don says the V12 cap was made some years ago. Surely the tooling still exists to make more?
This is the kind of thing the club and this forum should focus on. A comprehensive list of suppliers should be posted permanently somewhere on the CLC site or this forum. I'm not talking just aboutthose who advertise in the SS, either. It should be set up where users can add vendors whenever they find a new one. If someone is out of business or whatever, a quick note to a moderator could update it as needed.
It would save lots of repeat questions. How many times in one week do I post Daytona Parts' information for carb questions?
fward
Don Rundgren
There is a surprisingly long list of repro parts in the back of the CCCA Bulletin, most of these are offered by the regions as fund-raising efforts. There is stuff for Cadillac, Packards, Lincolns, Pierce Arrow, etc. but unfortunately no ignition parts. If the club could set sometning like this up I would definitely be interested in a cap and rotor for my 32.
Don
McKinney, Texas
Stinson
I hope the CLC will take up this venture! I would also order a cap and rotor.
Ty Stinson
Ty Stinson
CLC22330
Bob Hoffmann CLC#96
#19
Lots of ideas & wishes posted here, but the fact remains, WHO'S GONNA DO THE WORK? The CLC has NEVER  done a reproduction project! What makes any of you believe they will start now? The Classic Car Club has regions that do projects. They list them in the back of the bulletin. The time when most of the restoration work was done on multi cylinder Cadillacs has PAST!.  Interest level is low. Some cap & rotor reproduction was done years ago. I don't remember what. So... here's the same message I seem to have to post. Someone needs to step up with the time & money & MAKE IT HAPPEN. Talk is always cheap! I am willing to guide an interested person with some contacts & past history that might help. HTH, Bob
