First year for 6 way power seat GM 1957 ?
Started by Jeff Maltby 4194, October 23, 2009, 01:17:53 PM
Jeff Maltby 4194
Can anyone identify this front seat assembly/switch ?
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Jeff Maltby 4194
More pictures.
Jeffo 49er chapter
CLC 1985
Walter Youshock
1956 was the first year for 6-way seat.  That switch doesn't look like '56 Cadillac, though.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Barry Norman
Could possibly be a Chrysler--definitely not Ford--the switches look GM-ish. Never seen one exactly like that !
Barry Norman
J. Gomez
#4
Quote from: Jeff Maltby 4194 on October 23, 2009, 01:17:53 PM
Jeff,
The seat assembly is from the 1956, maybe early 1956 ?? There was a conversion added to the 1956 part of 363 0752 kit (spring pensioner) which the one on your picture does not have. I have two one with (attached picture) and one without (same as the one in your picture) the kit. The 1957 assembly changed drastically, the 1957 type the motor plus solenoid were on the left side (driver) versus the 1956 these were on the right side passenger.
As for the switch is looks like it is for the 1957, the 1956 is a slider, and the 1958 has a tab at the center switch.
J. Gomez
CLC #23082
Walter Youshock
It's not a '57 switch.  All 3 buttons on the early switches were a single piece and moved in unison.  For example, if you wanted to mov the seat forward, you would push the center button forward and the 2 tilt tabs also move forward.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
J. Gomez
Quote from: Walter Youshock on October 23, 2009, 02:51:48 PM
Walter,
From the illustration on the Master Parts (a bit blurred) it seems the 1957/58 escutcheon has three individual squares openings for the switches, I though these were separate switches. I failed to notice the slider knob control.  :-[
Thanks for the clarification..!
J. Gomez
CLC #23082
57flw
Hi Jeff,
Here is a couple of photos out of my 1957 Fleetwood.
As you can see there is some differences.
Sorry I could not have been more helpful.
Ken
Ken Francis
Hervey Bay
Queensland, Australia
1957 Series 60 Special Fleetwood
Skype: fleetwood1957
J. Gomez
#8
Jeff,
As I mention on PM..!
After a closer looks at the first picture of the mounting side, I can only see mounting holes at the rear, and I do not see any at the front. The second set is also not detailed from the front.
So I would say this is not from a Cadillac, possible Buick or Oldsmobile ??? The attached pictures show my unit mounting at the front (sorry could not get a good angle for the inside shoot). You can see the front selenoid on the second, and the front mounting holes.
J. Gomez
CLC #23082
carguyblack
 I agree that for the most part, it certainly looks like a Cadillac with the exception of the mounting track to the floor. It is not like my 56 Cadillac track at all. The switch is a mystery as well.
Chuck Dykstra
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
JungleCadd
#10
Quote from: J. Gomez on October 23, 2009, 02:38:58 PMJeff,
Oh man that is good stuff. I have that bracket from a swap out but spring is Mia. Which set up do you recommend? With the added third spring?
56 Eldo Seville
JungleCadd
Wondering if I have the right spring.
Schematic shows duplicate springs for outboard left and right. 34.0520. But one looks larger. Also I have this monster that came w a box of goodies.
56 Eldo Seville
