Engine swap 69-72, 472 in.
Started by Soren Johnson, May 06, 2011, 04:49:12 PM
Soren Johnson
Had my engine in my -72 Deville changed in to a -69 engine.
Did not do any of the job myself.
Got the car back and it don't seem to run powerful, it lacks power when I put the pedal to the floor.
The mechanic says he have done what he can.
But I am wondering over one thing.
Can I rely use the distributor from -72 on an -69 engine?
I was thinking about -72 being the smog engine.
Soren Johnson, Sweden
The base timing and timing advance curves are different, you should use the 69 dist and base timing setting.
Quite a difference in the engines IF the '69 is still built to it's original specs.  Compression ratio of 10.5:1 for the '69 Vs. 8.5:1 for the '72.  Use the '69 distributor or have yours re calibrated to the '69 specs, and the '69 carb should be used as well.
Greg
Soren Johnson
Many thanks for your advices :-)
Soren Johnson
What is the difference between -72 carb and -69 carb?
