1957 brake booster won't release brakes
Started by wannerstudios, July 09, 2011, 07:12:43 PM
Jon S
Have you checked the brake push rod length?  It's an adjustable rod attached to the brake pedal with a nut and locking nut for adjustment.  If it's too long, your power brakes WILL lock up and not release for some time.  The length of the push rod must be adjusted to 4 7/8" +/- 1/8".  This is the distance from the pedal reinforcement to the retainer seal and a picture can be found on Page 8-6 of the 1957 Shop Manual.  I will bet yours is in excess of 4 7/8"!  A simple fix!  Let me know what you find.
Jon
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
David King (kz78hy)
The dimension in the manual was wrong and Cadillac Serviceman bulletin was noted that had the correct dimension.  I will have to look it up, but the most important thing is to make sure the pedal comes all the way back up so the master cylinder gets a recharge.
The correct dimension is 4 7/8" but you measure from the forward in car (back side of the pedal frame) instead of the graphic which shows the cross bar which is more rearward in car.  May 1957 pp 46 Serviceman is the note.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
cadman49
where do you guys get that neets foot oil and where exactly where do you put it in??? r king--57 de ville
Quentin Hall
Most saddlery stores here in Oz have neets foot oil. However any good quality leather dressing should condition the leather if it is dried out.
Interesting about the pedal measurement....though that would also affect the brakes even if the booster was not connected...so unlikely the problem I'm experiencing.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Jon S
Quote from: David King  (kz78hy) on November 16, 2013, 05:31:14 PM
David
David -
Could you post a picture of the Serviceman note please.
Jon
Jon
1981 Corvette
2004 Mustang GT
Jon S
Jon
1981 Corvette
2004 Mustang GT
With a little help from abroad!
Quentin Hall
G'day Roger, Thanks Mate. When you say "With a little help from abroad!" . . . are you meaning that you got a woman to do it for you ??
     Sorry . . . I couldn't resist. Q
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
57 Biarritz
Sorry, cannot understand your remark...makes no sense to me.
Jon S
Quote from: Roger Zimmermann on November 20, 2013, 02:34:42 AM
George -
Fantastic!  Thank you very much!  I just checked mine and it is on the mark.
Jon
Jon
1981 Corvette
2004 Mustang GT
David King (kz78hy)
Thanks Roger,  I have been busy and not checking the forum as much.
David
David King
CLC 22014  (life)
1955 Eldorado #277
2012 Volt
Quote from: David King  (kz78hy) on November 23, 2013, 09:02:09 PM
No problem David, if I can supply some info I'll do it...
Renato
R. Bognar
