1973 Coupe DeVille courtesy lights wont shut off
Started by thevinylking69, November 22, 2011, 10:02:28 PM
thevinylking69
The courtesy lights on my two doors and the 2 in the back wont turn off when the doors close so i had to disconnect the fuse so my battery wont die. Is this a switch or a short? Could someone please let me know, it would be much appreciated.
     Chuck
jagbuxx #12944
Sounds like a short. Check the cigar lighters for any metal objects in them. Also, check for any blown fuses. Seems I remeber a "body" fuse when blown could cause this issue.
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
thevinylking69
I think there is some cigarette foil in one, and a screw in another, i will remove those and see what happens, where would the body fuse be?, in the cabin fuse box? because i replaced all of the fuses in the cabin fuse box.
Thank you very much,
    Chuck
Don’t forget that the headlight switch when turned all the way in one direction (clockwise?) turns on the interior lights.
