How do you clean the Filter Element on a bat wing air cleaner ?
Started by Bill Balkie 24172, March 26, 2012, 09:17:23 AM
Bill Balkie 24172
Hello,
    The bat wing air cleaner  has two eliment housing that should be cleaned with kerosine every 5,000 miles  according to the sticker on each pod . Not sure about how do do this . do you soak each pod in a bucket of Kero . or do these things come apart somehow ?
     Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
Bill Balkie 24172
Well , i ended up soaking each pod in Kerosine over night and blowing the eliment out with an airhose . i hope its ok .
  Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
