2005 CTS-V windows
Started by Lars Kneller 8246, March 31, 2012, 11:45:34 AM
Lars Kneller 8246
The automatic up feature on my V's front windows has stopped working. Anyone have any ideas where to look first for the problem?  The automatic down works for all 4 windows, and the windows work fine otherwise. Thanks.
936CD69
The auto up function is programmable. If battery power is interupted, the control module in the doors may loose one or more preferences. Try lowering both windows, then one at a time, hold the switch in the up position around 5 seconds after the window is completely up. If that doesn't restore the function, it may be a defective module in the drivers door. Best to have a dealer diagnose in that case, the new module is around $175.
I hope this helps, Lars!
Craig Brillhart CLC# 26217
1993 Sedan deVille Spring Edition Carmine Red White Top-SOLD!
1993 Sedan deVille Spring Edition Triple Black
CLCMRC Benefactor #302
Lars Kneller 8246
Craig, thanks so much, that fixed the problem. I did recently have to replace the battery.
