1946 chassis ID number location?
Started by 1960 coupe de ville, April 01, 2012, 11:10:00 PM
1960 coupe de ville
Could somebody please tell me the location of the chassis number on a 1946 series 62?
Jason Gendrolius.
Jeff Hansen
On top of the passenger side frame rail between the starter and the battery.  It will be a seven digit number that for a 1946 series 62 should begin with "84".
If you have the original engine, the same number will appear on the block just above the water pump.
See photo.
Jeff
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
1960 coupe de ville
Jason Gendrolius.
