1977 Eldorado door lock problem
Started by joecaristo, October 25, 2012, 12:23:12 PM
joecaristo
My 77 Eldo drivers side works only. You hit the door lock button from either door and the drivers door locks and unlocks only. Passenger side nothing.  I took the door panel off on the pass side and everything is connected. Wiggled wires while hitting door button and nothing on pass side. I hear the relay working. Before I drill the actuator out, any body have this happen to their Eldo?
Joe
Joe Caristo
LeRoy DeVol
Joe, I have never owned a Eldorado but i have had 2 Cads. of the 60's and i had similar problems with the door locks & electric seats. With both cars the problem was the same. The wiring from the switch in the door was broken where it go's thru the bulkhead to under the dash. I removed the rubber boot around the wires and found the broken wires . I installed new wires &
spliced them to the wires in the door & under the dash and that was the end of problem. The driver side door gets opened & closed 10 times as much as the other doors and there are 3 times as many wires to flex & break. I have to assume at least the door lock switch is in the door.
Lee DeVol
I assume that lock does move manually?
Guidematic
Easy check. See if the actuator is getting power in both the up and down position. Just place a test light across the 2 terminals on the actuator and it should light in both directions. If it does, the actuator is defective, if not, look for wiring issues.
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
joecaristo
Thanks everyone. Yes the lock works manually.
Joe
Joe Caristo
