Air bubbles in fuel
Started by NO1CHAUFFEUR, March 04, 2013, 12:35:35 PM
NO1CHAUFFEUR
My 1949 Series 62 has air bubbles in the fuel pump bowl, and the see-thru filter, any ideas what may be causing this?
Walter Youshock
The fuel bowl housing may be warped and no longer making a good seal between the glass bowl, gasket and the housing.  Remove the glass bowl and gasket and place the glass bowl back on the filter housing.  If you can rock it back and forth and it's not making full contact then it could be the problem.  Remove the filter housing and GENTLY reform it in a vise.  They'll warp from heat and tightening the bowl hold down.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
TMoore - NTCLC
This is also caused by a leak in the fuel line - not one that will seep gas out so that you can easily see it, but a very minute leak.
Check the connection to the fuel tank - this can be a source of air getting into the system, and make sure all of the line is in good shape (steel and rubber), and the connections along the way are all tight, including the inlet to the pump.
TonyZappone #2624
I have owned I don't know how many Cadillacs, thirties through sixties.  I can't think of one of them that didn't bubble in the filter bowl, usually when the car is hot.  I can't think of any incident where it affected the running of the car.  If it runs good leave it alone.
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2016 Cadillac CT6 Platinum
Jay Friedman
I agree with Tony.  I have a '49 too and sometimes there are bubbles in the fuel pump filter bowl and sometimes there are not.  Leave it alone unless it runs poorly.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
