1969 CAD STICKER REGLUING
Started by 1969cadillac, April 15, 2013, 04:59:44 PM
1969cadillac
Hello    , i peeled the coolant sticker off under the hood to fix some rust , what is the best glue to put it back on??
thanks , murray mules
cadillacmike68
I'm not sure. I would go to a crafts shop and ask about a high heat resistant glue.
"Cadillac" Mike
Gene Beaird
I'll start by saying that I've _never_ used this stuff to re-glue vinyl stickers, but if I had to, I'd certainly try it and see.  I'd try Bare Metal Foil Adhesive:
http://www.megahobby.com/bare-metalfoiladhesive.aspx
It's a liquid that you apply with a brush and then let dry a bit.  It works well for it's intended purposes, which is adhering foil to plastic model kits.  I don't know how it would last under the hood of a car.  It certainly wouldn't be as permanent as weatherstrip adhesive or contact cement, which I think is what you would want.  OTOH, super weatherstrip adhesive would certainly be permanent, but the chemistry may attack the old vinyl.  Be careful.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
