My New Project: 1956 Cadillac Sedan Deville Resurrection Thread
Started by chstitans42, September 27, 2013, 12:10:11 AM
0 Members and 6 Guests are viewing this topic.
chstitans42
chstitans42
chstitans42
I got the shoes fixed today and the oil pump rebuilt. Im sure I could have gotten by with using all the old gears inside the pump, but figured I might as well since I have it out. I also read that the new spring in the kit is stronger than the one that the car came with (it was two whole coils longer) So I used the original spring again.
chstitans42
DeVille68
yeah, luckily I could avoid having to reopen the brakes.
My service manual for 68 has a quite detailed list of instructions.
From which brand is the brake hardware? (springs and such)
J. Gomez
Ben,
Just a note on the brakes..!
I was checking the brake gap per the Service Manual and was not able to get them properly set. So I had to redo mine a few months back after my last complete overhaul.
You will notice there is a slot on the drums; this is used to insert the gauge to gap both pads around the drum. The Service Manual recommends an adjustment in page 7-9 under major adjustments. Although time consuming I was able to get them properly set.
Just a hint..!
J. Gomez
CLC #23082
DeVille68
Quote from: J. Gomez on September 24, 2014, 12:37:45 PM
So you mean the star wheel?
It is a lot easier to do a "first" adjustment while not having the drum on. Afterwards you can't see and you need to wiggle around with a screw driver and piece of wire. The idea is to lift the adjuster lever to be able to turn the star wheel in any direction necessary. After that, a few backwards stops will get them properly adjusted. If not (that happened to me) you need to adjust the star wheel again. My star wheel is probably bad, hence manual adjustments needed.
J. Gomez
Quote from: DeVille68 on September 24, 2014, 01:22:31 PM
Nicolas,
No the slot is on the face of the drum itself (facing the wheel). I’m not sure how far Cadillac had these places on the drums; I believe it will not be applicable in the 1968.
J. Gomez
CLC #23082
DeVille68
Quote from: J. Gomez on September 24, 2014, 01:37:31 PM
Nicolas,
ah, yes. The slot is on the backing plate. But the idea is the same. My 68 Caddy has the slot in the drum itself.
chstitans42
Bill Young
I really respect what You are doing , Your reward will be a superrior running absolutely stunning 1956 Sedan DeVille. A model and Year I have admired since I was a child. I am 60.
BIGTOM
Ben!
Your work is awesome! I'm going to be ready to pick back up with my project this spring and I am continually reminded of the feeling of satisfaction you must be getting while bringing this car back out from under that tree!!! Keep up the good work man!
chstitans42
chstitans42
chstitans42
Chuck Swanson
Not sure how it's supposed to look as I mainly work on mid 60's -69, but I get all of my lines from Inline tube.  Link to '56:
http://inlinetube.com/Preformed%20Lines/Web%20Line%20Listings/CA-CAT-02.htm
so they may have the various lines you need.
Chuck
CLC Lifetime
AACA Lifetime
66 Sedan DeVille hdtp
66 Calais pillar sedan
66 Series 75 9-pass limo
65 Fleetwood
07 DTS w/ Performance pkg.
69 Dodge Coronet R/T
chstitans42
Andrew Trout
Engine parts are looking awesome!
When is the engine block supposed to come back from the builder?
Rochester, NY
1961 Convertible
chstitans42
