pictures of clutch and bell housing etc 41 60 special
Started by mr41cadillac, December 09, 2013, 11:01:28 AM
mr41cadillac
I need pictures of the assembly of the clutch etc to the back of the engine on 346 1941 Cadillac 60 special. thanks john
That.s self explanatory John. Bell housing on first, can only go one way. Flywheel sides up from the bottom, can only bolt on one way also as I recall, drive and pressure plate go through the bottom together, then the arm and bearing?   unless there's some other reason you need pictures?
Bill Ingler #7799
Hi John: Maybe this is what you need?  Bill
