Replacing Hydro-Lectric line 49 60S
Started by Paul Phillips, May 06, 2014, 08:58:57 AM
Paul Phillips
Has anyone done a replacement of the steel line from bottom of firewall that runs to under the front seat area?  Trying to understand what the first connection point is under the seat (guessing it may be a T or distribution manifold, as lines going to the B pillar leave this area.  More important, how much needs to be removed in order to access this connection under the seat?
Thanks in advance for your advice
Paul
Paul Phillips CLC#27214
1941 60 Special (6019S)
1949 60 Special (6069X)
