need help on temp gauge
Started by stephen hill, July 11, 2014, 05:09:04 PM
stephen hill
I have a 1940 sixty special and the temp gauge only works if I tap on the gauge front. if I keep taping it goes to hot. I took off the wire to the sender if I ground it (short time only) it goes to hot I have bought a new correct sender. any body please steve 25502
stephen hill clc#25502
Julien Abrahams
To me it appears that there is a(n internal) problem with the gauge itself. Did you try switching the gauge. I do realize that's usually easier said than done.
1951 Buick Eight special
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
MY 59
Agree with Julian, unfortunately I would not be focusing on the sender, but it is an easy try to see if it helps rather than pulling the gauge
good luck :)
David Bone :)
1959 Cadillac Sedan Deville
1967 (aussie) ZA ford Fairlane
Richardonly
If you have access to another gauge, DON'T  install it.  JUST connect the wire to it and ground it and see what it reads........OR..
The wire to the gauge may also be the problem, so run a replacement test wire to it, sender to gauge, (even outside of car as it's just a test) , disconnecting the original, NOT REMOVING IT, to see if that corrects the problem.
If either or both work, then make a permanant repair.
Best of luck, Richard
1948 Cadillac Fleetwood 60S
1995 Jaguar XJ6
stephen hill
thanks for all the help . I think I have a extra gauge will look for it  steve
