Clutch pedal bushing 37 LaSalle
Started by Lou Kish, August 02, 2015, 05:48:46 PM
Lou Kish
Would anyone out there know of the part number or better yet, a supplier, for the bronze bushing pressed into the pedal arm that pivots on the shaft attached to the frame and bell housing on a series 50 1937 LaSalle?  Thanks, Lou
Lou Kish - 1937 LaSalle opera coupe
Jay Friedman
The part number is 402 448.  The same bushing was used in Series 50 and 60 from 1935 to 38, and in '38 commercial chassis vehicles.
If you can't find one as a Cadillac part, a good parts man might be able to match it with a bushing used on another model or make of car.  Also, some king pin bushings are very similar and there may be one that would match.
Another solution is MSC (http://www.mscdirect.com/browse/tn/Motion-Control-Fluid-Power/Sleeve-Bearings?searchterm=bronze+bushing&navid=4287924442) a company which sells many sizes of bronze bushings.  Maybe one would fit.  You'd have to drill a hole in it for the grease fitting
After measuring the diameter of the shaft, the easiest solution might be to take the pedal, with the old bushing if you have it, to a machine shop and have them make a new bushing on a lathe and press it in for you.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Lou Kish
I appreciate the part number and it will give me a starting point for my search.  I was hoping to find an available replacement part, thinking they have worn out for many a car of this era.  If anyone comes across a source, please let me know.
Thanks for the info,  ;D
Lou
In all my years I have never seen these bushes advertised Lou. Much quicker to get the local machine shop to make a new one as Jay said.
