76 eldorado 500 CID injected - california car - need ecu with #1608340
Started by 240cpa, September 24, 2015, 04:08:08 PM
240cpa
I know this has been asked before but can someone point me to a source for a reman ECU or an honest rebuilder?
Thank you.
Dan LeBlanc
Look up Bruce Roe on this forum. By far, hands down he's the best guy to tackle this.
Dan LeBlanc
Quote from: 240cpaI know this has been asked before but can someone point me to a
Someone said GM still lists them, around $400, but I don't know if they are actually in stock.  If
you send me an email, I can send you a list of ECUs that will work for you.  bcroe@juno.com
And some other stuff.  Although you have a CA car, a 1608339 49 state ECU would work just fine.
In any case yours can be repaired for a lot less than the above here.  Read about 70s Cad EFI
on my PHOTOBUCKET, first album.
     http://s93.photobucket.com/albums/L71/bcroe/
  click on an Album
  click on a picture to enlarge + description
BRUCE ROE                                  bcroe@juno.com
5719 EAST SKINNER ROAD,
STILLMAN VLY, IL    61084-9215
Phone  815 234-8039
bill06447
This number is available through Standard Motor Products but according to their website is on a 4-8 week back order.
Bill
Quote from: bill06447 on September 26, 2015, 10:15:18 PM
Bill
Somebody should order it and see if anything happens in 8 weeks.  Being out of production for
nearly 4 decades, I would expect shipment either from stock, or never.  Bruce Roe
If they were readily available and worked well I don't think Bruce would be so busy.    Even with how many Bruce apparently deals with in a year I can't see a big company bothering to deal with these things.
bill06447
 I'm just passing along information from Rock Auto, I'm neither endorsing or trashing any one's product. there are five oe numbers in stock ACDelco reman $364 with exchange unfortunately his California one isn't on the list so it looks like your best bet is to send it off to someone to get it rebuilt.  They aren't complicated; if it were mine I'd open it up, spend some time with a multimeter and fix whatever went bad in it myself. That's pretty much what you get with a rebuilt anyway. The external fuel pump relay modification looks to me to be a must-do regardless of what you decide.
Bill
Quote from: bill06447I'm just passing along information from Rock Auto, I'm neither endorsing or trashing any one's product. there are five oe numbers in stock ACDelco reman $364 with exchange unfortunately his California one isn't on the list so it looks like your best bet is to send it off to someone to get it rebuilt.  They aren't complicated; if it were mine I'd open it up, spend some time with a multimeter and fix whatever went bad in it myself. That's pretty much what you get with a rebuilt anyway.  Bill
As I said there are a few different number ECUs that will interchange, essentially any 76 for the
500 engine.  I would say they aren't hard to fix IF you have a drawing of what the circuit is and a
good understanding of analog computing circuits and an engine simulator to control or read out
every pin to simulate operation.  A multimeter won't do it; you had better have a good storage
oscilloscope.  Without those you are looking at a circuit with no part identification numbers and 5
totally custom ICs not documented anywhere, along with some high failure parts no longer available.
Fortunately the circuit is available now; 76 ECU is the second album on my PHOTOBUCKET above.
The engine simulator is pretty simple, only 3 pulse generators and a couple pots.  The custom ICs
are still mysterious, the General made all but one go away for 77.  Replacing a MAP with a 9.5V
supply and 7.3V output can be managed.  Bruce Roe
