1954 Front end alignment question
Started by 54 caddy larry, December 07, 2015, 08:28:36 PM
54 caddy larry
Is there a different camber setting when going from bias-ply to radial, my tire shoppes alignment machine doesn't differentiate between the two. My car has some wander to it, the front end is tight and all parts check out to be good. The tire shop actually suggested that that I check here with you guys, they all willing to learn something new so they can get the job right for me.
Thanks in advance,
Larry
Larry M
1954 series 62 coupe
1974 Harley Davidson FLH
My caddy is my never ending work in progress.
Dan LeBlanc
Yes, there is a difference.
Bias ply tires like to have about 1/8" toe in, radials, 1/16".
Bias ply tires use negative caster, radials positive.  I believe 2.5 degrees positive caster will give the best results.
Dan LeBlanc
Jon S
Quote from: Dan LeBlanc on December 08, 2015, 08:00:48 AM
I have never changed the alignment on mine and the last set of Radials had 60,000+ miles and wore straight across.  Car tracks and handles perfectly.  Not so sure you need to modify the alignment specs, but each car is different.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
54 caddy larry
The tire shop reduced the toe in 6 degrees on each side, wander is now gone. That would be in line with what you suggested Dan.
Bottom line, problem solved.
Larry
Larry M
