Buid sheet questions - 1959
Started by Blade, February 14, 2016, 03:53:23 PM
Blade
I just pulled out my build sheet and still have a couple of things not clear on it for me, if anyone could please answer these I would appreciate it: 1) Order number -- I would think it is the number of order that came in but it's a low two digit number for my convertible which is a later build (May '59) this is then not very logical. 2) after each production numbers there is a number 6 - some has a 6K - these are not included in the VINs. In almost all cases it's a '6's or '6K's except the sheet also contains a commercial chassis order (style Z) which has a '7' after it. Anyone has any information on what these are?
Thank you!
wrefakis
order number is for the outlet in large market areas there will be larger numbers
the 6 or 6k numbers are engine numbers the k is for car with ac
