1957 series 62 heating duct help needed
Started by mcain, February 21, 2016, 02:33:36 PM
mcain
I have a 1957 series 62 and trying to reassemble the dash and heating ductwork.. does anyone have any pictures they can send me of the heater ductwork from the driver side all the way to the passenger?  Trying to fit the flex duct between the break pedal and then have the cardboard pieces that also attach to the flex duct.. but cant seem to fit the duct work as well as dont know how to bolt on the cardboard (it has hangers)
many thanks!
chris cunliffe
There are only 2 pieces of ducting that connect from the heater to the passenger side .The flexible duct fixes to the heater box and runs across the steering column then connects to the cardboard tube which fixes to the lower lip on the dash panel in the orientation in photo 2. This is then connected to the duct behind the passenger side kick panel (photo 3) by a rubber bellows.You may not have this as they tended to harden and fall apart due to heat and age, and unfortunately are not currently being reproduced. On my own car I had a perished bellows and managed to salvage it using duct tape ,but a short section of inner tube would probably work.
1957 Eldorado Seville #967
mcain
thanks Chris.. this was helpful.  do you happen to have any pictures that you can send of the flex duct installed?  The way I have installed it seems to be sticking out in the way of the gas pedal..
thank you!
Cadillac Jack 82
CLC Member #30850
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
57 Eldo Seville
Quote from: 57shark82 on February 25, 2016, 04:00:51 PM
This might help you:
http://cadillacpartsltd.com/19ca19ca3pca.html
I purchased these ducts but they are for the engine compartment side of the heating and air conditioning systems (as noted in the product description) which are accessed through the panels in the inner fender.  Two of the three fit well but I ended up using some 5" duct material from McVeys instead of the 5" duct supplied for the air duct cover to the heater blower motor.
Dave Morris
Dave Morris
CLC#28497
2020 CT5-V
57eldoking
Looking thru my nearly 3000 1957 Eldorado pictures this is unfortunately the best I have. Probably won't help you much.
1957 Eldorado Biarritz #906
1957 Eldorado Biarritz #1020 http://bit.ly/1kTvFlM
1957 Eldorado Seville  #1777 http://bit.ly/1T3Uo1c
1995 Fleetwood Brougham  http://bit.ly/20YwJV4
2010 SRX Performance
1946 Chevy 1/2 ton pickup
1957 Buick Caballero Estate Wagon (x2)
1960 Chevy Apache 10 Stepside
1991 Jeep Grand Wagoneer (x2)
1992 Pontiac Trans Sport GT
Walter Youshock
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
57eldoking
57 Eldo Seville
Here is a pic where the duct passes over the steering column.
Dave Morris
CLC#28497
2020 CT5-V
mcain
Thanks everyone!  And Dave, really appreciate you sending the picture!
chris cunliffe
Dave, I don't think that brake pedal return spring is exactly factory.
57 Eldo Seville
I agree completely!  And since I am finally getting the brake system working right, that spring needs to go.  I understand it was a common modification.
Dave Morris
CLC#28497
2020 CT5-V
It seems that '57 cars are affected by this problem of a brake pedal not returning completely. My '57 Brougham suffered from the same malady. I installed a spring at the frame under the car, so it does not offense the eyes!
