siezed wheel NUT? 57 Cad
Started by 60eldo, August 24, 2016, 10:12:11 AM
0 Members and 4 Guests are viewing this topic.
60eldo
    Drivers front wheel nuts seem to be seized. Is it possable they are reversed threads
Jon. Kluczynski
Jon S
They are indeed Left hand threads and should have a L punched in the end of the stud.  They loosten clockwise.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
60eldo
Jon. Kluczynski
At least you asked rather than just figuring you needed more power and start breaking things.    I ran into that not that long ago on a medium duty truck.   On that thing not only was one side reversed but the studs on the rear where what held the inner wheel on.
Skwerly62
Quote from: 60eldo on August 24, 2016, 10:45:30 AM
  Thankyou I feel stupid :-\
I just did the same thing on my 58. Thankfully I was patient and ONLY used a 5' extension pipe trying the 'wrong' way!
1958 Extended Deck 62 Sedan SOLD
1960 Coupe - current project
USCG Vet - Fly CG!
Dan LeBlanc
Ran into that on a 52 Pontiac I had once.  I tried the opposite way with the impact wrench thinking an little back and forth may help loosen it up.  Shock of my life when I put the impact on forward and the lug nut came off without issue.
Dan LeBlanc
Jeepers Creepers
Did they continue the left hand thread system into the sixties?
What was the cutoff year?
Kevin and Astrid Campbell
Australia
Dan LeBlanc
My 61 Fleetwood is not equipped as such.
Dan LeBlanc
60eldo
#8
  I also  have a  1969  Charger R/T reversed thread
Jon. Kluczynski
I had a 70 Challenger with reverse threads on the drivers side.
Very dumb idea.
Walter Youshock
Not really.  The idea was that the nuts would tighten on both sides of the car when moving forward.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
59-in-pieces
Johnny,
I made the mistake of taking my 59 to a tire shop here in town to mount some new 2.25" white walls.
I did not stick around - dummmmm.
Got a call that the shop had a problem.
Some kid with a air impack gun - fit for a Sherman tank, spun the nuts off 2 studs and then stopped.
The threads on the stud were gone.
So lesson learned - I don't have a tire changing machine - and would never turn my car over to these young BOZOS for any other reason.
I have had enough Cads to keep a bunch of left hand studs and lug nuts around, because I have learned some people just change the driver side to lefty "loosy" - righty "tighty" studs, to avoid such a problem - but not me, no - damn the torpedoes and full speed ahead for OEM.
Shame on me for not sticking around or explaining.
Have fun,
Steve B.
S. Butcher
My 62 Olds had L and R, hardly a problem since they were clearly marked.
But I had so many issues with shops damaging or mounting rims and lugs,
I long ago refused to let them touch my car.  I roll the old tires in, and roll
the new ones out; no more replacing damaged parts.  Bruce Roe
So did everyone use left threads in that era?    Did Chev?  Ford?  Sounds like Mopar did.
Jeepers Creepers
Here in Australia, the local mopars had has lefty's until about 69 or 70 then went normal from there.
I'm sure we had a few others as well.
Australia
V63
I've gotten in the habit of painting the reverse thread stud (ends) and nuts a bright yellow.
I've had cars with BOTH L and R studs on the same wheel!
Painting them helps too when you have them lose in inventory in a lug nut box or wherever...easy to pick em out!
Leftys are normal! As in  'Abby Normal!'
Quote from: V63
That is because someone already broke off a left thread stud and replaced
it with a right thread stud.  Bruce Roe
V63
L & R threads on one wheel...
Oh yes, that's what I figured...but what a hot mess
Or drums mounted on the wrong side is another scenario...
willits
Quote from: Jeepers Creepers on August 24, 2016, 01:49:48 PM
The last year for LH threads would have had to been either '58 or '59   My '58 had LH threads orginally.  When I upgraded to roller front wheel bearings I used '60 drums & hubs and those have RH threads.
Peter
Peter Willits
1958 Coupe DeVille http://bit.ly/1O6BGVu
1961 62 Convertible http://bit.ly/1O6BHst
2008 STS-V http://bit.ly/1O6CI3P
