1957 Cadillac Eldorado Seville Underbody
Started by Seville1957, August 24, 2016, 06:15:33 PM
Seville1957
Hey guys,
I've been told that the under bodies were painted a red oxide primer. Anyone out there that painted their under bodies with red oxide primer? Anyone find a correct source? I have been looking at Rust Seal's Red Oxide rust proofing paint but didn't know if that would be close to the original.
Cadillac Jack 82
Mine has black undercoating which was typically done at the dealership
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Seville1957
Mine has undercoating as well but would like to get rid of that and go with the factory look. Would love to find something close to factory color with rust proofing properties!
Eldovert
Willie,
What I see being done during restoration is a coating of epoxy primer followed by a urethane paint that has been tinted and flattened to look like red oxide primer..any competent paint shop should be able mix something up fairly close,
Cheers,Pat MacPhail
Walter Youshock
With the red oxide, there should also be a bit of body color overspray along the edges of the body.  The didn't mask off the floor when painting the car.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Seville1957
