1955 Autonic Eye Installation.
Started by RandyK, December 15, 2016, 10:50:18 PM
RandyK
RandyK Dallas. I am seeking any information on installing a Autronic Eye in my 1955 Cadillac Coupe DeVille.  All info welcomed.
RandyK
J. Gomez
Quote from: RandyK on December 15, 2016, 10:50:18 PM
Randy,
Are you try to add the Autronic-eye option to yours?   ???
You will need all of the hardware parts for it, the amplifier which goes on the engine compartment left side (driver) front fender, the power relay just next to the amplifier, the override foot switch, the photo tube on the dash, the wiring hardness, etc.
In addition you will need to modify the existing headlight wiring to set up the Autronic-eye. In all not an easy task and on the other side these are going for two arms and two legs for the complete set big $$$$.   :o
Good luck..!
J. Gomez
CLC #23082
