changing weather strips on my 74 Eldorado Convertible
Started by Seachange01, May 12, 2017, 05:47:01 PM
Seachange01
Hi guys,
I have a brand new set of weather strips, some adhesive and some adhesive remover all just waiting out in my garage for me to come out this Sunday and remove the old set and put the new ones in :)
It seems like a fairly straight forward task. Has anyone done this before? if so, any tips for a first timer? (I have the whole gluing and the best way to get a good adhesion all down pat), Just looking to make sure there is nothing too tricky, or deceptively easy to miss, that could bring me undone ;)
Alan
chrisntam
Make sure you use the black weatherstrip adhesive, not the yellow.  Invariably, some will squish out.  If it does, it stays yellow FOREVER.
I fixed that issue, sold the car.
1970 Deville Convertible
Dallas, Texas
Go online and try to search for videos from Steele Rubber Products.
They had one of their people on an episode of My Classic Car showing the correct way to glue weatherstripping into the car.
Less is more. They showed applying a thin even film on both surfaces.
I've installed weatherstripping with the 3M adhesive and applied it more like mustard on a hot dog and got the squish of yellow goo mentioned above. They may also have a black adhesive available
YouTube is a great resource for seeing different repair methods on everything. I usually watch some videos that are relevant to get ideas.
Good luck and post pics please.
Brian
Seachange01
Quote from: 76eldo on May 12, 2017, 07:04:19 PM
Thanks Brian,
I know the video you mean, I have actually watched it. Great tips for gluing styles.
Brian
Mike Josephic CLC #3877
Weather-stripping adhesive is technically called a "contact cement".
Read on to see why.
Follow the application directions to get a correct, long-lasting seal.
All that is needed is to first put a thin coat evenly covering both
surfaces.  Then, allow it to dry for the number of minutes specified
in the directions.  Failure to do this step properly will give you a weak bond.
Once dried as per directions CAREFULLY press the two sides together.  It
grabs instantly "on conract" and cannot be finessed / moved afterwards.
That's why it's important to try the fit of the weather strips first to see if any
trimming or if alignment issues are present.
3M black (as mentioned previously) is what you need to use.  Steele makes the
best replacement rubber parts (IMHO).
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
