Heater Core Help!
Started by Sconnors, September 14, 2017, 05:29:32 PM
Sconnors
Hi guys
Just got off the phone with my mechanic. He's replaced my heater core with a new one and got everything back together and no heat! The top side is hot, the bottom side is cold, but there is anti-freeze going through the both.
Any ideas???
Scott Connors
Caddy Wizard
Air bubble trapped in the heater core.
Art Gardner
1958 Eldo Seville (2/3 done)
Sconnors
He bypassed the heater control valve and has heat! So I'm ordering a new one now!
Scott Connors
Bobby B
Quote from: Art Gardner  CLC 23021 on September 14, 2017, 05:35:54 PM
Yessiree...... ;D
                Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Honestly, a mechanic replaces a heater core, which presumably was by-passed and the only reason to do it was for heat, and then does not check after completing the job to see if the heat works - really?  Then it is a forum post, another drop off and pick up, another wait for the part, and etc.  As I get older, my patience for this type of mechanic wanes.  Probably not a good idea to get any brake work done by this mechanic.  Sorry you suffered through it.  Another testimonial as to why I became my own best mechanic.  Even though I can paint, plumb pipes, wire and etc., often it is hired out because life is short, but for work on our older cars life is too short not to do it yourself.
Sorry if the mechanic is your brother and it worked when he tested and etc., but circumstantially you got my honest reaction.
Enjoy the heat in you Cadillac this winter!
