1941 Cadillac 6019SF Division Window & Motior
Started by Virgil Perkins, April 21, 2018, 11:26:40 AM
Virgil Perkins
Does anyone have the schematics for the division window & motor for 1941 60 Special? And/or any instructions for replacement of the motor? I had this apart 14 years ago but did not take enough photos and did not make enough notes of all wiring. The memory is less than desired here, and hindsight is 20/20. Thanks in advance for ANYTHING anyone has.
Virgil Perkins
Jeff Hansen
Virgil,
See if this helps.
Let us know if you have questions!
Jeff
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Virgil Perkins
#2
Jeff, that is perfect!! And I just found several more photos I took back when, including 11 with wiring and routing information tags on each. I must have realized the need for future reference 14 years ago, too bad the memory is rusting out present day. THANK YOU JEFF!
Virgil Perkins
gary griffin
Virgil,
   I am in the 7th year of restoring my 1942, and in some cases I am looking at my restoration blog as I was posting fairly regularly and the pictures and comments made during the 7 years are jotting my memory. Most pictures were lost when I accidentally destroyed my cell phone.
   Jeff Hansen has been a good contributor to my restoration for sure along with many other members of the CLC club.
Gary Griffin
Virgil Perkins
Gary, I have done the same during bringing Miss Betty back to life. I also print out all photos, just in case I screw up sometime and wipe out my folders of photos. Jeff Hansen and several other folks have been quite helpful via our forum, one reason I joined the  CLC back in 2002. Figured if I was gonna ask for help I should be able to give back when I could.
Virgil Perkins
Jeff Hansen
Glad it helped you out, Virgil!
I appreciate your and Gary's kind words.  The fun part of the hobby is helping each other out to keep these beauties on the road and functioning as they were originally intended.
Jeff
Jeff Hansen
