Is it ok to leave the a/c system under vacuum for a day or two?
Started by chrisntam, May 20, 2018, 10:17:34 PM
chrisntam
Got the compressor replaced, put oil in the sump (based on what was removed & per FSM), hung the drier and put it on the vacuum pump for about 1.5 hours.  It drew down to about 29.  Closed the gauge valves and it's holding steady.
I'm tired and will put the Freon in in a day or two.
Is that ok?
I know, it's a little late now, but I can't imagine it would be a problem.  If anything, I'm checking for leaks longer.
With that said, should I turn the vac pump back on for a bit longer prior to loading the Freon in?
I'll keep hand turning over the clutch plate to move the oil around....
chris.
1970 Deville Convertible
Dallas, Texas
I always do that after major surgery on ac system, and have used same good quality pump for years now, probably over 100 times for 24 hours on a single system.
chrisntam
You leave the vacuum pump on for 24 hours?  Or let it sit at -29 with the pump off?
Pump is currently off....
Dallas, Texas
Chris,
The shaft seal is intended to hold pressure. Assuming you have primed the oil pump and lubrcated the seal, to leave the system under vacuum, again assuming there are no leaks elsewhere might tend to suck the lube off the seal leaving it dry when you start it up.
chrisntam
After sitting overnight (about 11 hours) the low side gauge went from 29 1/2 to about 28 3/4.  Hoping the loss is at the gauges or gauge connections.
I'll charge it up and check for leaks.
Dallas, Texas
I do not leave the vacuum pump connected to the ac system if it is not running.  However, I may let it vacuum for 24 hours if I did major surgery, such as replace compressor, hoses, and etc.  You cannot have too much vacuum and too little moisture in the system.  BTW that small of a vacuum change could be related to a change in temperature or a slight leak in pump seal on vacuum pump.
chrisntam
Charged it up this morning (I would have rather been watching Perry Mason on METV), took it for a test drive, at it's coldest, it was blowing about 40 degrees out the vents (when on max/recirculate).  About 78 degrees outside.  When on auto, it seemed to be a bit warmer.  I was expecting it to be a lot colder.  We'll see how it goes.
Have to go to work now.   >:(
Thanks for the input, it is appreciated!
chris.
Dallas, Texas
Chris
38 degrees is as low as your system is supposed to get under your conditions. Is the site glass full and are you still using R12?
chrisntam
Dallas, Texas
