Cadillac 346 engine coolant
Started by houseboats1, August 06, 2018, 07:22:39 AM
houseboats1
Can any one tell me what type of coolant to use in a 346 engine please
Thanks Mark I'm in Australia it doesn't snow where we live
Jim Miller
Mark
When I purchased my '41, the guys all said to use the original type green Prestone. They also cautioned about using a strong flush. So I just flushed with plain water. Looked at Evans Waterless Coolant but too many pros and cons so I decided to stay with original. It was also suggested i find a spare 9 pound radiator cap to keep on the shelf.
Jim
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2021 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
Bill Ingler #7799
Jim:  As you probably already know , the RC-7 cap for your 41 is getting hard to find and expensive. If you do not drive your car for a long period of time, back your cap off a half a turn. If a cap is screwed tight on the radiator for a long period of time, the thin rubber sealing gasket on bottom of the cap can become stuck to the sealing flange of the radiator neck. Taking the cap off can destroy the rubber seal. I had it happen on my 47. I now put a tinny amount of silicone lubricant on rubber seal to prevent sticking of the rubber seal to the neck flange .  Bill
Jim Miller
Thanks Bill. I did find a spare RC7 cap. But I will follow the other suggestions also.
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2021 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
Mike Josephic CLC #3877
Whether it gets cold enough to snow or not, you
should still add antifreeze to your cooling system.
I addition to providing protection against freezing
of the coolant, antifreeze also has corrosion inhibitors
that protect the radiator and engine block against
the effects of water.  Water, as I'm sure you know,
corrodes the radiator and causes rust in the engine
block. Antifreeze also contains a lubricant for your
water pump.
The standard "green" antifreeze is what you need.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Bobby B
Quote from: Mike Josephic  CLC #3877 on August 06, 2018, 08:54:08 PM
Agree with all of the above  ;)......
                                  Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
houseboats1
Thanks for the good advice. Much appreciated!
Regards Mark
Quentin Hall
Where in Oz and what car do you have Mark?
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
amolnayak
I have recently restored my 1940 Lasalle 52 coupe and been driving it around in Mumbai India. The temperatures here are 32C minimum and generally bumper to bumper traffic. My engine is unopened and I had flushed the block thoroughly by opening the water jackets and fixing new ones.
Initially i used only pure coolant and I would loose almost 2 litres of it on a 10km ride in no traffic. However after the advice of some seniors here I have diluted the coolant heavily and even in crazy traffic the temperature at the head does not exceed 200F . I have been checking with a laser thermometer. The loss of coolant and water is negligible. The key really is to get the correct water coolant proportion so the rust is inhibited but yet there is enough water which is a better conductor o heat than the coolant.
1940 Lasalle 5227C
1956 Mercedes Benz 180D
1956 Fiat 1100 103E
1961 Rover P5 (now sold)
1992 Eunos Roadster V series special
houseboats1
Quote from: Quentin Hall on August 08, 2018, 01:09:35 AM
I live in Nowra NSW and I have a 1939 60 special
