'67 Eldorado Purchase; Question
Started by joecadillac63, April 30, 2019, 12:35:58 PM
Bob Hoffmann CLC#96
Charles,
Sorry, but you are incorrect. The non vinyl cars are smooth steel. The same steel as the vinyl tops.
Bob
joecadillac63
I did not know that - I am not very knowledgeable about these cars yet, but will be eventually as I was with 63's!  Sounds like I better start hunting.....
None
Previous:
1963 6267 Series 62 Convertible Coupe
1969 69347 Fleetwood Eldorado Coupe
1967 69347 Fleetwood Eldorado Coupe
Cadillac Fleetwood
Quote from: Bob Hoffmann CLC#96 on May 09, 2019, 09:13:57 PM
Charles,
Bob
Thanks, Bob.
Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
Flyer
Joe- There is a salvage yard in Idaho that has a 1967 ECP on their lot. You might check with them on the window trim. L & L Classic Auto, Wendell, ID 208 536 6607. I have a 1967 that is Pinecrest Green with green interior. Check the August, 2018 Self-Starter for a picture. Good luck with the car. If I can help you in anyway send me a PM.
Hugh Dean
joecadillac63
Nice looking car, Hugh - and I will give the yard in ID a call.  Slim chance...but you didn't work in Orange, Texas years ago, did you?
Joe
None
Previous:
J. Skelly
Charles,
I pulled the moldings off of a 1968 Eldorado in a Detroit junkyard several years ago.  It had a factory painted top, and the moldings are steel.  Some pieces are too rusted to use, but I thought they could at least be used for patterns if no one ever reproduces them.  Are you saying that all 1967 Eldorados used stainless steel rear window moldings?
Jim Skelly, CLC #15958
1968 Eldorado
1977 Eldorado Biarritz
1971 Eldorado (RIP)
Cadillac Fleetwood
Quote from: J. Skelly on May 10, 2019, 06:42:56 PM
Charles,
No.  I was not correct.  As Bob correctly stated, the non-vinyl roof cars have mouldings that are painted steel. They are not stainless. I did not proof-read what I had written, being too concerned about the plain (non-vinyl roof) versus textured (vinyl roof-equipped) mouldings.  Sorry for the confusion.
-Charles Fares
1989 Fleetwood
Jerry Puma
Congratulations on your purchase! I looked at that car last September in North Collins NY a few hours after it appeared on Craig's List. Oddly, it was listed on the Rochester NY Craig's, rather than Buffalo. In any case, it was purchased while I was making the 40 minute drive to look at it - just missed it! It had been taken off the lot, but the shop owner let me look at it anyway. I would have bought it on the spot. He said he sold it to a couple guys from Buffalo for $2900. I was surprised to see it surface on eBay being offered in Eden NY. I wonder if the original deal from September fell through?
Jerry Puma
1964 Eldorado
1961 Series 62 6-window
The rear window molding is the same for 67 through 70 Eldorados, but as mentioned above cars with the roof covering have the roof pattern stamped into the molding.  The slick top cars have smooth moldings.
Is it possible to put a light coat of putty on the molding to cover the stamped pattern?
J. Skelly
Charles,
thanks for the clarification
Glen,
I know of a guy in the Detroit area who had the vinyl top removed from his '68.  Since he had the correct textured moldings used with the vinyl top, and the smooth moldings are about impossible to find, he had a shop mill the moldings to make them smoother.  Then the remaining texture was filled in with putty.  It was done so well that they looked like factory non-vinyl moldings.  I wonder how well the putty and paint will hold up on the moldings after a period of time.
1968 Eldorado
1971 Eldorado (RIP)
