Throttle Return Spring Bracket / Holder
Started by 6262, July 02, 2019, 04:04:16 PM
6262
I need this for a 1962 Cadillac :
1962 Cadillac Series 62
1965 Pontiac Bonneville
Caddyholic
never seen that before. both of mine hook on a hole on the power steering pump bracket. forward of the carb.
1962 Coupe Deville
Doesn't look good enough to be a factory made bracket.
Quote from: The Tassie Devil(le) on July 02, 2019, 08:42:45 PM
I don't know... It is a '63. I have included the picture for illustrational purposes.
Quote from: Caddyholic on July 02, 2019, 05:30:05 PM
This problem is haunting me from day one. The car always had a makeshift throttle return spring. Now I have an expensive reproduction which is shorter. Do you know if yours is correct? Do you have a picture?
Caddyholic
Is it 63 engine? I don’t know 63 engines
1962 Coupe Deville
6262
No, it is a matching numbers '62 engine in a '62 Cadillac. I have included the picture strictly for illustrational purposes because I was not sure if I use the appropriate terms for the issue.
6262
Attaching it to the power steering pump bracket works as you have said. So I need no bracket because there was no bracket.
Thank you all!
Bobby B
Every picture on Google has it on the Power Steering Pump Bracket......
                                                      Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
fishnjim
Just a matter of finding the right spring.
Many have been modified when they change carbs, manifolds, etc.   Best to go to a motor cut away or illustration when looking for these levels of detail like in the specifications - GM Heritage archives - download for free.   Or shop manual or parts list.   Absence of a part is also valuable to know.   If it ain't in there, it don't belong.
Big Fins
#9
Here is where mine was factory.
BTW...That's a '62 Engine in a '59 car.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
G'day John,
I can't see that arrangement as being factory simply because the spring is not at 90 degrees to the throttle shaft.
Any offset of the spring will result is a sideways pull on the shaft, so every time the thottle is opened, the spring will be pulling the shaft sideways, and over time, will wear out the pulled side within the carby.
Caddyholic
Here is a picture of my 62
1962 Coupe Deville
Big Fins
#12
Quote from: The Tassie Devil(le) on July 05, 2019, 08:50:33 PM
G'day John,
I gotta agree with you. But that's where it was when I bought it, so I ASSumed it was correct. So...that is where I put it when when the engine was put back in.
Looking at 6262's pictures, his P/S pump sits up high on the engine, whereas mine was down lower mounted to the block and exhaust manifold.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
My '60 CDV had a 454 and TH400 when I purchased it, and the replacement engine I purchased was from a '61, and that had the pump sitting up high.
I mounted the return springs towards the rear as it had the Holley 650 spread bore carby from the 454, and I had to fabricate the kickdown bracketry to attach to the throttle lever, to run the factory '60 Transmission kickdown lever.
Big Fins
The reasoning I got was that the original purchaser liked to do his own service work and hated the oil filter canister. So, he purchased a newer engine and added all of the 59 accessories to the newer engine.  ::)
Who, is 1959 that could afford a Cadillac did their own service? I thought Cadillac ownership then, showed you were a 'made man'.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
6262
Quote from: fishnjim on July 05, 2019, 11:31:09 AM
Jim, can you point to an illustration which solves the problem? I have the shop manual and the MPL but have not seen a picture which answers my question.
I think I have the right spring because I have bought this item:
https://www.ebay.com/itm/Cadillac-throttle-return-spring-for-1957-1961-and-1962-with-single-4-bbl-/223482320823
Quote from: Big Fins on July 05, 2019, 02:15:43 PM
Thank you.
This is the reason why my friend who owns the '63 in the first picture has this bracket. He holds the same opinion as you.
Quote from: Caddyholic on July 05, 2019, 10:06:29 PM
Thank you.
Quote from: Big Fins on July 06, 2019, 05:26:04 AM
I think I have found a proof that the throttle return spring indeed attaches to the power steering pump. The second and third picture show how my actual car looks now. However I recognize in this moment that my spring has now the opposite direction than Caddyholic's and Big Fins'.  ???
