1932 Cadillac V16 scale model
Yann, thanks for those memories !
The second picture is remembering how different Americans can be from people from Europe (at least the countries I know): as you can see, there were glasses full of I suppose ice tea. Not my gusto for a dinner, so I went to the side desk to order a bottle of red wine. The lady who spoke with me was disoriented: what would you like? a glass of red wine? No, the complete bottle! She had to ask other people what that would cost as it seems that ordering a complete bottle is unusual...Of course, I did not drank the whole bottle myself!
Finally, the valve covers were finished by adding the décor on top. The lines were machined with a very narrow milling tool and the décor soft welded on the cover. The original parts are aluminum, with the décor polished, the remaining surfaces being black. As my parts are made with brass, the covers will be chromed and painted like the original parts.
The question I was faced was: with what will I continue? After switching between gear box and water pump, I opted for the water pump and the 3 water tubes, two on the passenger side and one on the left side.
Mike Baillargeon #15848
Baillargeon
#15848
Thanks Mike!
As I wrote earlier, I began the water pump. That damn part is full of curves; almost nothing is straight, with the exception of the attaching brackets to the crankcase. Even if I have many pictures from that element, I had difficulties to begin the work. Finally, I opted for the water pump cover. The base is now done but the pipe coming from the radiator which is casted with the cover is not yet done, because I don't know how to begin it. It has an elbow at its lower part, plus a provision for a petcock. It goes towards the crankcase, rendering it asymmetrical.  Maybe I will take a bit of brass and carve it.
A solution will come, like for the pump's body but I don't know when.
Finally, the water pump cover is ready. Maybe not ready for paint, but there will be only cosmetic improvements, if any. The "long" tube was done with a full bar; the end on which the rubber hose will be attached is a short tube silver soldered on the bar. That assembly was then silver soldered on the cover you saw recently. Other small details were soft soldered.
It's now the turn to the main body for the pump. Again a battle to get it, but not as bad as the one in the Capitol.
Lexi
Roger I see some apparent solder stains on part of this work. I do not think that would have been on the original cast iron piece :D  LOL. Seriously, looking good and I am astonished by your fine attention to detail. Happy New Year. Clay/Lexi
Thanks Clay! The solder is there on purpose, to make a fillet!
carguyblack
I think I know how Stonehenge and the Pyramids were built...... by Roger!
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
No, no, no Chuck: I was not yet born and I don't like old stones!
Lexi
Chuck, Roger can't be that old! Stonehenge is ancient. But perhaps he built "Carhenge" in this era??? Check out the '55 Caddy mounted on top. Looks like Roger's handy work to me. Clay/Lexi
carguyblack
I'm sure everyone knows that I didn't mean to imply age but rather ability. Roger, it's a long way from Switzerland to Michigan to bop me over the head for a perceived insult, anyway! Watching the progress, I continue to be amazed at your skill level and patience. What a joy for some of us who don't even have opposing thumbs to see this level of possibility and reality in you, Roger. Hard not to be jealous!
Stay well,
Chuck
Chuck Dykstra
1956 Sedan DeVille
1989 Bonneville SSE
Chuck, I did understand the joke, no problem! I just did not know what would be a good answer...One part of my previous answer was indeed appropriate: I'm not good at working with gravel, stones, concrete...So, the pyramids and me are two separate entities!
After a short vacation, the work resumed on the water pump. After the front cover, I began the rear part of the pump which is more or less flat. I silver soldered this plate to the "legs" which are attaching the pump to the block. I did a hole into that plate which is the axis for the impeller; it must be more or less aligned with the one from the generator. Rubber couplings are used at both ends as a solid shaft was not realistic due to the production variation.
As I did not know how to continue the rear part, I did the pump's front flange; on the picture, this part is on the floor near the block. Most probably, the part between the front flange and the back will be solid; then, once the exterior shape will be acceptable, I will do a large hole in the middle to save some weight.
Alex D.
Roger, I am always in WOW of the talent and attention to detail that you have. As an owner of a V12 version of the V16 I can appreciate the challenge you are facing. If I may point out, The draft tube on the generator should be at the bottom and an air intake on the top.
1932 370B  V12
Alex, thanks for your comments. You are right about the draft tube: it's not in the right position. I forgot to mention that I'll let it that way, so it will not be damaged when the crankcase is on the working table.
As you may imagine, I'm glad that the pump is ready. Such a small part and so complex! I'm pretty sure that it's not a 100% exact replicate of a real one; working with pictures is not quite easy. There is always one picture missing to see this or that detail or the relation between two elements!
The first picture is showing the 3 elements for the pump. The hole in the center is the "fil rouge" as with an inserted shaft I had at least the correct position of the 3 elements relative to each others.
The body on the second picture is ready and on the last two, the pump is installed on the crankcase. This time, the generator is in his correct position; it will be removed for the subsequent jobs which will be the fabrication of the two tubes between the pump and the crankcase and head and the long one located the other side.
CadillacGlasses
I wish there was a 'like button' for all your updates, this is looking awesome
M. Herbert
29645 - CLC West of Lake, CLCMRC Board Member
1949 Series 62 Conv. (in progress)
carguyblack
I agree with Mike. Usually, I don't have anything intelligent to add to the conversation and I'll bet there are a lot out there who feel the same. But, I'll also bet there are a bunch of us watching these posts with eager amazement. Roger, please continue the thread as you have been! Even though we may not input it, doesn't mean we are not captivated by it all. For me, it's a matter of deciding what to say to an mechanical Einstein when I hardly know which end of a screwdriver to hang on to - so I talk myself out of replying! Sincerely, thanks for continuing to update us on your progress and know we are with you all the way in spirit. Amazing work you are doing!
Chuck
Chuck Dykstra
1956 Sedan DeVille
1989 Bonneville SSE
Lexi
Ditto the last 2 comments. Clay/Lexi
Thanks for your comments! I know that it's difficult to make "intelligent" comments when people watching this thread are not involved into modeling. I however see that the number of views is growing!
