Carl 61 Fleetwood Phyllis
James Landi
"I am happy."   As are many of us who are following your extensive and lengthy restoration Carl.  Impressive accomplishments,expertise, and determination.  Happy day,  James
Clewisiii
I got the phone call.  My frame is ready.  Last week she said it was scheduled to start on the 25th now it is done on the 22nd.  I think I am taking a short day at work on Wednesday to go and pick it up.
The radiator should also be done by then
Clewisiii
I don't know how to interpret the difference between the bushings I bought 5 years ago. And the new set I have to reassemble my frame.
I like the way the rubber is molded in the new ones.  But the previous drawn metal casing seems smoother.  But I think it may also be weaker.  The upper flange was bending quite a bit when I was pressing the old ones in.  IMG_20230522_204135467.jpg
Clewisiii
Can someone tell me about these.  Because I do not remember taking them off.  Screenshot_20230522-214458.jpg
Could they be the locking tabs for locking the rear Universal Joint to the Diff Pinion Flange?
Quote from: The Tassie Devil(le) on May 23, 2023, 02:05:05 AMCould they be the locking tabs for locking the rear Universal Joint to the Diff Pinion Flange?
Exactly. Were used from 1957 to 1962 and 63-65 on 75, CC.
Clewisiii
I picked up my frame and brackets from the powdercoater.  Hard to get that off my trailer alone without scraping it.  I will unpackaged all the little bits and work on getting it back together this weekend.
IMG_20230524_131953934.jpgIMG_20230524_145524713_HDR.jpgIMG_20230524_145704537_HDR.jpg
Clewisiii
Another pic in the garage .
Clewisiii
#508
I picked up my freshly recored radiator today.  I had told them don't worry about painting it.  I will do that myself.  I am glad I did.
First thing I noticed that the new copper side plats were solid and smooth.  I asked him about the holes for the radiator overflow tube clips.  He said in 30 years he has never had anyone ask about that.   He said I can cut holes in the plate as long as I do not go deep.
I loaded it in my trunk and was a mile down the road until I noticed something in my memory.  The overflow tube coming out of the fill neck was pointed in the wrong direction.  It was pointing forward.  I pulled into a strip club parking lot and checked my trunk.  Yup it is backwards.  I turned around and went back.  He looked at it and I showed him a picture.  He called a guy up and asked him to take it off and resolder.  I showed him the picture were it is to the back angled to the outside edge.  I talked to the guy at the counter for a while and he came back with the tank.  Tube angled to the back middle of the tank.  Well third time is the charm.  He went back and fixed it.
I know things happen. And no one is perfect. And how were they supposed to know what angle the tube needed on a 61 Cadillac.  But that only explains the first mistake. Not the second.  I am going to go measure everything to make sure the overall dimensions are correct.  It would suck to find out the new core is 1/2 inch taller or shorter and will not fit in place.
Clewisiii
Installing these upper A Arm bumpers was much easier this time.  No fighting at all. They pulled right through IMG_20230525_185135488.jpg
Clewisiii
I was worried about buying these because they were from a generic listing that did not say application or size.  I almost feel I lucked out on a perfect fit
When I have to fit tight rubber parts, a dab of Rubber Grease works well.
PS.   Don't forget that having previously done the same task, the second time around is usually easier, as you know just how much the parts will take to get them in.
Clewisiii
I got the ignition wire harness from Electric Limited today.  Just getting the stuff needed for starting the car for now.
But I have some problems with the Bushing/Ball joint kit I bought from A Resto Parts.  They are just slightly off.
The new pins are shorter then the old set from Rare Parts.
The new A Arm bushings are to small. They can slide in by hand.  So I will need to order a new pair of these bushings.  I don't know about the lower yet.
Clewisiii
Every little success or step forward should be celebrated.
And any step back is just another opportunity for a different step forward.
The goal should be the act of doing.  Not the end product.
Otherwise you may go insane.
Clewisiii
I realized my parts car has the trans linkage shield in place.  I hope it is covered with enough oil to have survived intact.
Clewisiii
Found the locks.
Some reason I was thinking they would be larger.
And still reuseable.   Only one each of the locking tabs has been bent.
Clewisiii
It has been in the 90s this week. I decided I did not want to work out in the barn after work. But it has only gotten up to 74 in the barn so I could have done something.
I bought a new set of press collars and tools. And some sheet rubber to protect the parts during pressing.
I have been very happy with the restored fasteners I have gotten from Jason Edge. But I have to be careful with the dog.  These are expensive bolts and if I put one down he takes off with it.
Clewisiii
Pressing in those upper A Arm bushings sucks.  They do not fixture or support well. And the support damaged my fresh powdercoating.  But I can touch up the scrapes with some POR15.
Clewisiii
I had NOT forgotten how much of a pain it is to install and align the bolts for this rear yoke.
But this was easier then the first time. Able to fit it with a lot less beating.
IMG_20230604_093321701_HDR.jpgIMG_20230604_093953023.jpgIMG_20230604_094623273.jpgIMG_20230604_094659342.jpg
