Carl 61 Fleetwood Phyllis
Caddyholic
axels are not painted from the factory.
1962 Coupe Deville
Clewisiii
I picked up a set of these fender protectors today. They are old and brittle. I may just use the. As templates to make new ones. IMG_20230926_190135113.jpg
Clewisiii
I finally got my front bumper all the way apart. I need to take all the brackets and have them powder coated.
Even though I have new chrome bumpers I am not throwing away this set.
I may refinish them to have a spare. IMG_20230929_164947389.jpgIMG_20230929_203220780.jpg
Clewisiii
I was debating what to do this weekend. And decided it is finally time to install the pipes to the manifolds.
Clewisiii
I need to loose weight. Out of shape I was getting dizzy laying on my back going side to side to install and torque down those pipes.
But I am amazed how well they lined up. Bent by hand, welded, off of a 60 year old pattern. It is amazing to me that the bends and angles could be that accurate.  Waldrons is awesome. The torque spec is different from rh to lh. But I did them both at the upper spec.
Next I can make the connections from my trans coolant lines to the radiator. But that is another round of on my back under the engine so I will give it a couple of hours.
Do I detect a massive paint run on the Transmission Bellhousing?
Looking at the powder-coated frame, make sure that everywhere that a grounding strap attachment, that you completely get rid of the coating so that the grounding will actually ground.   Remember that grounds are everywhere, from the Battery Negative terminal, all the way back to the number plate lights.
Clewisiii
Quote from: The Tassie Devil(le) on September 30, 2023, 07:33:05 PMDo I detect a massive paint run on the Transmission Bellhousing?
yes that was from the Eastwood paint coat years ago. The stuff dried real slow and on the clean aluminum it just slid.
I ran a tap in every ground straps hold and sanded the surface under the strap.
Clewisiii
I cannot believe it. I just realized I installed this top splash shield upsidedown on one side. I will need to take it off and flip it.
Commiserations on getting it wrong, but congratulations for showing that you are human.
At least the holes should be self-sealing when the staples are removed.
Clewisiii
Well I will be able to work on my car this weekend.
I got a call leaving work yesterday asking how long my Passport was still good for. They wanted me in England to talk with McLaren for some of their interior products manufacturing.
But by 10 this morning it was cancelled.
I am still waiting on my drive shaft. They have had it since September 1st. I call once a week to ask if they have a price estimate. Last Thursday they said they were working on it and would call me at the end of the day. That has not happened yet.
I will call again tomorrow. I cannot pick it up until the 12th at the earliest anyway.
After I pay for the drive shaft I have a big order to Amsoil waiting for me to pay as well.
Clewisiii
The drive shaft shop finally gave me a price. And I should be able to pick it up at the end of next week.
Clewisiii
So a new dash wire harness is $1000 from Lectric Limited. I want to just go with a new one so I can get rid of these crusty terminals. IMG_20231007_102627499.jpgIMG_20231007_102609243.jpgIMG_20231007_102634934.jpg
But they want the original to use the fuse block and bulk head connector. IMG_20231007_102618845.jpg
I called them and asked about the trunk release switch. They said the trunk release is not a part of the IP harness. Well they are right. If you had trunk release a jumper was plugged into the clock power terminal. So I went through and stripped everything that is not actually part of the harness.IMG_20231007_103455942.jpg
Clewisiii
Looking for fuel for the first start. The ethanol free is 91 octane. I would have liked better, but I don't see a need for the racing fuels.
The price is on the pump with stickers. So I don't think it changes that often.
Clewisiii
Well 2 to 3 weeks to start my car. Which I will be very happy for.  The drive shaft should be back next week. And I think I will have the rear end gone through in November.
But I cannot put the body on until I paint the firewall. And I cannot do that until more prep and sanding. It soon will be to cold to do that outside and I do not want to sand in my newly renovated ship.
So I cleaned up my basement work area today.
I am going to start working through more of the dash panel. I will get the new wire harness, repaint the lower Dash. Then slowly send out parts for chrome plating. I should be able to get a fair bit done before next summer.
I need to get back to the seat frames. I decided I am changing some of the springs I used. The new seat back springs are to stiff. I may even put the original foam back. It was latex foam and is still very plush. I just need to clean it. It has aired out nicely in storage over the last 7 years. IMG_20231007_215855410.jpg
Clewisiii
This radio and speakers are in very rough shape. But they were actually working when I took the car apart. Well the front at least.
These are some other things I would like to get done before summer. IMG_20231008_093032579.jpgIMG_20231008_093039323.jpgIMG_20231008_093042704.jpg
jwwseville60
The Lazy-Boy chair might just fit.
Lifetime CLC
Clewisiii
Quote from: jwwseville60 on October 08, 2023, 07:09:19 PMThe Lazy-Boy chair might just fit.
I am a fat man. I have to be comfortable no matter which shop I am in. The shorter one is for my dog. But he always takes mine when I get up. IMG_20231008_192630226.jpg
jwwseville60
Sweet!
I have easy chairs and a couch in my garage.
Lifetime CLC
If I had those in my garage, nothing would get done.
Clewisiii
I think I am ready to fill with coolant. But I want a new radiator cap.
I am going to put in a gallon of water just to check for leaks. IMG_20231010_194609019.jpg
