71 to 76 Cadillac Eldorado Door - Hard Top / Convertible Interchangeable?
Started by alex cat, January 21, 2020, 11:59:12 AM
alex cat
I'm looking for a driver side door for my 74 Eldorado. I have found a door from a hard top but I want to be 100% sure it is interchangeable with the convertible door. When doing a search on car-part.com the doors for HT and C are listed separately but that could just be how the listing is and not mean anything. Does anyone know?
I’m 99 percent sure that the door is the same but the door glass is diffeeent.
Not sure how you will find this out unless someone here has swapped them before.
According to the parts book, there is just one number for the 71-75 Eldorado doors. RH: 1662610, LH 1662611.
When changing the door from a Coupe, make sure that you refit the brass wedge that is on the rear end of the old Convertible door.   You will need it.
MaR
I just swapped out my passenger door on my '74 convertible with a door from a '73 coupe. It will fit just fine, you will just have to swap out the door glass as they are different between the coupe and the convertible. You will also have to move your upper alignment striker from the old door to the new door.
'73 door:
Upper alignment striker on old door:
Old door off:
New door on:
